ORIGINAL: lagwagon120651
Just got a new Mezon 95 and minibox.Benched for the first time today and my readings are way off my old ice 100.I used to get 90 amps peak on the same setup.The Mezon only shows 55 amps@ full throttle.I checked all the settings with the minibox hooked up and i think everythings correct.Motrofly 5320, TP5000 8s,20x13 prop.
I'd say that the ICE was the one that was WAY off. Using the accumulated mAh consumed telemetry from my Mezon to my Jeti DC-16 radio, what I put back into the battery is rarely more than 1% off of what the Jeti told me I consumed, given efficiency losses in the charging setup, that argues that the Mezon is VERY accurate in its consumption readings.
Peter+
