RE: throttle curve or servo limits?engine idle
chadxp1, I set up my throttle on all my planes so that when the stick is all the way back, im idleing. I use a momentary switch on the transmitter to pull the servo further to cut off the motor. The trim, either analog or didgital, is used for slight adjustments only....Gene
