RCU Forums - View Single Post - throttle curve or servo limits?engine idle
Old 03-14-2013 | 04:59 AM
chadxp1
Default RE: throttle curve or servo limits?engine idle
Yeh, I use to fly nitro heli's so I am familiar with using a curve. I guess I should have asked the question
of which is better. I like the curve because one can set the end points and forget about them, but I dislike the curve
because the throttle may not be linear unless you setup all the curve points correctly. The advantage of using the
the servo limits is you don't need to mess with a curve and the throttle is linear. I'm still not sure what to use. I do know that a
problem with setting the lower limits of the throttle all the way to the bottom limit is the kill switch
will not work because there is no more room mechanically for the throttle arm to close. This is why I ask what is better. I'm using
a spektrum dx8 by the way.
