RE: Carb spitting out fuel
Ok the white color thingies are the reeds. The black carrier is used to prevent the reeds from moving up too high. The reeds should lay flat against the reed block that they screw onto. So you need to look closely at the block to see if the reeds are laying flat against it or not.
