RCU Forums - View Single Post - microballoons and what?
Old 03-15-2013 | 03:13 PM
RBACONS
Default RE: microballoons and what?
To answer your original question, the microballoons would be mixed with epoxy. The more microballoons, the easier the result is to sand. Gumming up the sandpaper shouldn't be a big issue. Just make sure the mixture still has a glossy sheen to it when you're done mixing. If you get the mixture too dry, it doesn't adhere as well. The reddish-brown micro balloons (phenolic) would be better in this application than the white ones (glass spheres).
