Listen to speed if you want a perfect glass cowl. Finishing resin is good stuff too, it flexes very well, just takes about 24 hours to set up well enough to sand. On ABS I also like to apply some glass cloth to the inside seams. The ABS cowl makes a great plug. You can use a releasing agent, wax or even a balloon over it to use it as a plug.
Go skin that cat Max.
