RE: J-3 cub Identifly.
Have the motor , esc and I think the right batt.
If you look a the first pic of the plane with the gear drive the prop is going to be mounted higher in the cowl. Should I just saw off the old motor mount ? And build another one ? or where can I find different motor mounts that work with the 4 screw backing plat that comes with my CSRC E8-S-10. Its alot shorter than the original table weight.
