RE: Eindecker EIII
Here is the new wing tip dry fitted together. The tip is one piece 1/8" Baltic Birch and I score the front where it curves the most with the laser.
There are tabs that slot into the double tip rib. The brace pieces in the rear are 1" wide Baltic Birch glued on the top and bottom of the tip that are tied back into rib 13.
Larry
