RCU Forums - View Single Post - THROTTLE RETURN SPRING
Old 09-18-2003 | 06:55 AM
bluefluffybunny1
Default RE: THROTTLE RETURN SPRING
dbow, many failsafes will shut down the throttle if voltage drops due to low battery but they cannot do anything if power is lost (for example you lose a battery pack connection or the receiver switch fails). Try unplugging your receiver battery pack with the controller held with throttle open and you will see what I mean.
You are lucky that you have not had this problem. My GS Storm has decided to desert me on several occassions and luckily the bodge return spring that I had meant that it only hit things at low speeds.
