New from Active Hobby, Turnbuckle Wrench and Ball End Tool now at Banzai Hobby
Aluminum Ball End Tool for OTA-R31 / Yokomo
It is a specialized tool comes in handy during the assembly of the rod end and the turnbuckle.
Hold firmly the rod end, you can work without damaging your hands.
Reversible design that matches the shape of the ball-end OTA-R31 & Yokomo (with holes).
12mm: Diameter 18mm /: length
Aluminum Turnbuckle Wrench (3mm/4mm)
You can turn the turnbuckle more in his narrow space to have a 30-degree angle to the bore, use both sides alternately.
• Supports 3mm and 4mm turnbuckles that are often used in RC drift cars and touring cars.
• Set the total length 82mm. I was working in pursuit of a design pattern which is excellent in and hold appropriate length.
Please Join us on Facebook for Weekly Updates and Specials
Banzai Hobby Team
