RE: V-Tail Incidence
Kevin, the vee tail seat being parallel to the wing can only work if the fuselage under the tailplane is non tapered....I have to agree with the previous correspondent.If you draw a cross section through the fuselage/ tailplane at both leading and trailing edges you'll see why regards trevor H
