RE: DLE 35RA going to 3 blade prop
So someone tired the Scale 18X10 3 blade belia prop on the DLE35?
I tried and dle30 could not do it, it was low in the 4k range if mem is correct.
I tried it on the PTE36R at it was in the low 5k Range but the motor was not happy.
I put it on a BME 50 and got great power out of it, 7.5k range if I rember, I know I put it on my DLE55 also and it was in the 8k range.
But it takes power to move these scale props
Even the sweet 20X10 mopower, Im getting around 7300rpms at 10pic wich is great, just a little prop rip sound at wot.
I put this prop on my ZDZ80 Super J and got 5600 rpms at 14pich, and 7600 rpms at 12pich!
So when you see you have to jump up from a 55cc to an good 80cc to to keep almost the same rpms with just 2 more pich, its crazy.
But that 16in adjustable, it is really adjustable to anything you want, as you can put it at 9 pich or 11 pich etc, there are no hard teeth that make you have it exsactly one pich like Solo props
