RCU Forums - View Single Post - Anylink Problem
Old 03-19-2013 | 09:20 AM
bigedmustafa's Avatar
bigedmustafa
Default RE: Anylink Problem
I've been happy enough flying my AnyLink module on my Futaba 7C transmitter. I have notice that it can be picky about how well-seated the cable is in the buddy box port. Detaching and re-seating the cable can fix issues from time to time, while accidentally bumping or moving the module or cable while flying can cause it to quit working effectively.
The only other common issue that pops up is when several pilots are flying AnyLink modules. The receivers seem to bind to whatever is the strongest signal at the time I turn on my TxR plane. My Playmate and micro Super Cub will often bind themselves to the radio of somebody who is flying already rather than binding to my transmitter. Simply unplugging the flight battery from the plane and then moving further away from the other active AnyLink modules usually allows me to re-bind successfully.
Once two or more AnyLink modules are bound to their aircraft successfully, they can operate simultaneously while free from any interference.
I hope these suggestions help.
