RE: Viper 500 - Metal Bolt Warning
I hope you are using "BLUE" Locktite!
One question for Don. You said they are checking the tach readings to assure they don't go over 16,500.... what do people do that are blessed with a good TT 40 Pro that exceeds that limit(not too uncommon)? Do you:
A) - Back out the needle
B) - Throttle back
C) - Add a set amount of weight per each 100 RPM over 16,500
D) - Switch it with the Novice's engine
E) - Attach streamer to rear
Just curious since we don't check RPM's here in the east.
