RCU Forums - View Single Post - Sites for gas setup advice.
Old 03-19-2013 | 08:23 PM
Skerts
Default RE: Sites for gas setup advice.
Thanks acerc for your words of advice, I really do appreciate it. My decision for the power system now kind of hangs in the balance because it is only a 30cc plane. I do feel like I want to run two batteries though and I feel like I'd like to use an IBEC instead of a standalone ignition battery.
In your opinion how should I go about making this work? I should mention that I have a Spektrum DX7S with an 8 channel RX and my plane requires 6 servo's which leaves me with Bind, Gear and the AUX3 ports.
And as far as I can tell, the SmartFly BatShare has two inputs and two outputs so thats each battery to the inputs but for the outputs, should I run one to the RX and the other output to the IBEC? Or should I run both BatShare outputs to the RX and then plug the IBEC into the RX (is this even possible? haha).
Thanks again, I am learning a lot aha.
