RCU Forums - View Single Post - Bad Virbration
Old 09-18-2003 | 08:51 AM
glowplug
Default RE: Bad Virbration
Sounds strange considering your prop is in balance........couple of questions....
Have you tried a different Master Airscrew prop?
Is the prop hole reamed out larger than your engine's prop shaft?
Is the spinner a tighter fit with the MA prop than it was with the TF prop? (is it touching the prop anywhere)
