RE: DLE 35RA going to 3 blade prop
BubbasanJohn, Sorry about the delay getting back to you. If you have the Biela 16-10 3 blade it will probably work ok on the 35. I think the Master Airscrew 16-10 might be ok. If you have one mount it and see. If it turns over 8,500 rpm static, it is too small. While I had the G 38 on the engine stand (I think it is close to the power of the DLE 35) I mounted a Master Airscrew 3 blade 16-8. It turned 8,900 rpm. Too small, but the 16-10 MA might work,
