ORIGINAL:
[email protected]
Sounds like good advise falcon. What would you do where the water rudder servo hole is?should I try to find another way to rig it and move the servo?id rather not but I don't want to make my first glass job any more difficult than it has to be.
I would go over it as if it weren't there, then once the epoxy was hard ,(a day or so)I would cut it out with a small razor saw.an then coat it with whatever paint your going to use..its a box right, like a servo box not a hole looking down into the float?
