ORIGINAL:
[email protected]
Hmmm, lots more to think about. Is that pretty much common practice, or do a lot of folks take the easier route and mount the servo in the fuse with bell cranks or something?i don't want to skimp out and make cheesy floats or anything, but that's a bit of work. I guess you get what you put into it. Steve.
Its winter,,,take your time,,,I have seen a golden rod bent from tail wheel to water rudder...another is to use pull pull from nose gear,,or pull pull from tail wheel...another is to soder a water rudder to the tail wheel , if its a tail dagger.
for the one i am working on now it will get a servo burried with a hatch...an run servo wires along the wire landing gear.
