ORIGINAL: oddy
... goes inverted even for a second when the engine dies."
Thanks a lot.
Victor Arreola.
Seems iunlikely that just a second of inverted flight would cause the engine to die of fuel starvation. Will the engine run inverted on the ground? Perhaps the problem is in the kill circuit where a wire is shorting out the magneto only when the plane is inverted? Good luck.
