RCU Forums - View Single Post - 4S Practice Plane
Old 03-21-2013 | 05:38 PM
DrMotor
Default RE: 4S Practice Plane
More info: http://www.rcgroups.com/forums/showthread.php?t=1769672
It is made by "Winners Models" -actually says that on left wing; did a Google search on this ...
However, needs a motor larger than 140gHacker A30-14 L ; Torque 2814T/820 -size motor
They suggest motor: 1000-1250W, 230-250g, 4255, 4020 outrunner(-4255 would be size on external dimension? 4020 would be stator-size?)
Their suggested motor, a Dualsky XM4255EA-7, is 250g, Kv 505,42mm diam,49mm long (i.e. ~4250 -sizeon externaldimension); has 3535 stator.
A 4020 (stator-size) motor is, for instance:Hacker A50-14 XS V2 Kv564 (289g motor) -which is exactly same motor as: Torque 4014T/570 Kv 570, HYPERION Z4020 14T 574 KV, LipoliceLP-4020 /14T-550KV,Gens ACE Mars BL4841-550KV, 14T
-Could also use: Turnigy SK 5045-500kv; 280g; 16T or Turnigy SK3 5045-450kv; 280g; 18T, (these also have 4020 stator)
http://www.rcuniverse.com/forum/fb.asp?m=11427948
So: Put e.g. an SK3 orGens Ace motor in,get a ZTW ~70A ESC, and should berelatively inexpensive ... Takes 4S to 6S LiPo
PS: Weight of this plane is ~1.85kg, so inbetween Sebart Angel 30 (~1.3kg) and Angel / Wind 50 (~2.4kg).
-Can be described as 40-size plane, in between 30-size and 50-size ...
Mike, F3A Unlimitedshould get some of these for USA; It is a gorgeous beautiful thing ... It is mini Krill Spark ...
<span style="font-size: medium">I WANT ONE ...</span></p>
