regarding the thrust...
remember its 105N at ISA
use this and you should get it right:
http://wahiduddin.net/calc/calc_da.htm
if you test your turbine at lower temp than 20 degrees, then you will get more thrust at sea level... but it still only performs 105N at 20 degrees at sealevel called ISA
