RCU Forums - View Single Post - canard pusher config
Old 03-22-2013 | 07:57 AM
All Day Dan's Avatar
All Day Dan
Default RE: canard pusher config
Mick, If you don’t mind looking at me as I age, here are the images of the canards I built. The first three were set up 0-0-0 and they all required an eight of an inch up trim. The fourth one had two degrees of up incidence in the canard and it required no trim. The last one has two degrees of up trim in the canard and requires an eight of inch down trim. All the engines have no thrust angle built in.
Here’s a good website to help with the cg. I find it very accurate.
http://adamone.rchomepage.com/cg_canard.htm
Dan.
ID:	1865220   Click image for larger version
ID:	1865221   Click image for larger version
ID:	1865222   Click image for larger version
ID:	1865223   Click image for larger version
