In my opinion the P60SE is overdue an upgrade. It needs to use the V10 ECU and, unless they squeeze some more power out of it, it needs a price drop. There would be a place in the market for this engine if it was updated to current standards.
Is the P80SE still available? I was under the impression that production of this engine had ceased and the P90RXi was the replacement.
I've explained in my post above a couple of reasons why you might want a P90RXi instead of a P100RX. There must be a market for this engine as I am going to buy one eventually
WHY should you ever want a P140rx???
I agree if the price was the same as the P180RX but the P140RX is significantly cheaper. One solution might be for Jetcat to drop the price of the P180RX and stop production of the P140RX but that is never going to happen.
p.s. ISA standard temperature is 15 degrees C
