RCU Forums - View Single Post - 'Worst Stuck'
Old 09-18-2003 | 11:05 AM
dr_wogz
Default 'Worst Stuck'
Drat, did it again last night. Dribbled some thin CA on teh tip of my fingure, andit glued my finger nail to the tip of my finger. Hate that!!
And, don't we hate it when our fingres get glued to the pice you're tryign to glue, only to find it stuck better to your fingure?!
With that, I ask... What is your 'worst stuck' story?!
I remeber a time, one of the first airplanes Kev & I built; King Kobra Sheeted foam wings. No probs. Mix up a geneous amount of epoxy, slather it on the wing cores, and then add the sheeting. Press in the 'cradles' (the 'negative' from cut foam cores) to let cure. We were doing this on a coffee table, so it was easy to work on. When positioning the top 'cradle', I leaned over to check that all was OK, and my hair 'mated' with the epoxy mixing pad..... An 8.5 x 11 pad of paper generously layers with 5 minute old mixed 15 min epoxy...
Well, we all know, that epoxy waits for no one, so I had to set things right before cleaning up.. It took about two weeks for all teh epoxy to finally leave my hair!!
