RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 03-23-2013 | 02:14 PM
  #1152
husafreak's Avatar
husafreak
Default RE: Comp ARF BAE Hawk build thread
I am working on the Hawk wings and the Festo air connection on the main gear air cylinder is hitting the wing top surface (both sides). My options are to block up the gear mount about 2mm with ply strips or rotate the cylinders. I am hesitant to rotate the cylinders only because the flat head socket screws holding them seem very soft and very tight. I would have to heat them which might damage the rubber parts...
