RE: Twin nitro engine syncronizing gizmo?
Be very careful in trying to match rpms on twins, one will be a little less powerful than the other. You will end up with a lean engine if you are not careful, that is a dead engine on one side.
I tune one at the proper setting and than the other the same way, I do not try and tach to match RPM's I have seen others do that and the result is an engine that is not happy and stops in mid-air.
The plane will fly just great, both engines will function properly and No-one will ever know the difference
