RCU Forums - View Single Post - DLE - 55 Clockwise Rotating Engine
Old 03-23-2013 | 11:43 PM
  #32
ronald@kunenborg.nl's Avatar
[email protected]
Default RE: DLE - 55 Clockwise Rotating Engine
ORIGINAL: w8ye
The reason the cylinder cannot be turned around without modification is because of the reliefs for the reed block and rear bearing are different on the bottom of the cylinder.
Well all i can say is: did you try? No, because youre answer is wrong. theres no need for further modification in the dle55.
