RE: New Sebart Wind 50E
The ESC brake and BEC functions do not have any direct relationship so ideally using the brake doesn't affect the BEC output in any way.
There's an indirect relationship though: If using the brake heats the ESC up a lot, the BEC circuits will heat up as well and it's output power may drop as a result. That said, if you monitor the ESC temperature and it doesn't become hot, there shouldn't be any problems with the BEC function either.
