ORIGINAL: mcfast
A lot of 2-strokes have a off-set piston pin, so you mite have to rotate the piston and cylinder if you what the off-set to do what it was design for.
True statement about the offset pins but very rare in most of the engines we use. None of the engines discussed in this thread have offset pins, at least the ones I that I have measured and inspected. This is mostly done in automotive and other special use engines to reduce piston slap / knock when the engine is cold. Now some engines offset the whole cylinder in the case to gain a bit of power but again this is rare in our engines.
