RCU Forums - View Single Post - DLE - 55 Clockwise Rotating Engine
Old 03-24-2013 | 11:35 AM
  #46
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: DLE - 55 Clockwise Rotating Engine
On the DLE 55, all ones I've seen, had the port inlets and outlets internal to the cylinder and are the closed type and use a windowed piston to facilitate the air-fuel transfer. There are no ports at the bottom of the cylinder-crankcase mating area to consider. The cylinder gasket is the same, right side up or wrong side down. It is symmetrical left to right.
But the cylinder is relieved differently front and back for the rear bearing and the reed plate.
Also like several people have mentioned, there is no real mechanical reason to turn the cylinder around 180 degrees.  And there is no pin offset.
