RE: Another Outrigger Predator project!
Your photo shows the servo pushrod will hit main body of servo. Also the rudder hookup in last hole will have to be moved in at least 1 hole or the pushrod will have to be bent alittle straighter. Best to straighten rod some by 2mm which won't hurt excessive movement of rod. Now if you turn pushrod upor down will createexcessive movement and ease of movement of pushrod.
