ORIGINAL: Bob dunlop
Sounds good...intrested in seeing if the Loctite holds ...will you be able to unscrew the set screws and bolt at a later date or is it permanent like JB weld? ....only problem with JB weld is that it is permanent .
You can use a little heat and remove it if you need to. It is supposed to be a bearing retainer I have used if a bearing is a little loose. Has worked pretty good before so I will let you know if I have any issues.
