RE: Testing the new NV (Norvel) .40 size (6.5cc) gasoline glow engine
Based on my AX-40 manual from 5 years ago, it calls for turning the engine backwards with an electric starter before ever lubing or fueling the engine. The manual says that it comes with a special lube from the factory and spinning the engine dry with only the factory lube is the first part of the break-in process. I am not sure if that still applies to the gas engines or NV engines in general.
