Motor Mount: The directions for the installation of the motor are worthless. These instructions are better, but still out of date. My kit has twoallen headscrews to secure the two piece motor mount rather than one set screw. I guess all thattalk about dove tails didn't pan out. I don't know. http://www.axialracing.com/blog_posts/9974 Shocks: The illiustration tells you how the pieces go together, but it doesn't explain how the shocks should feel when properly assembled. … worthless[/b]. 1. Check for friction before putting any oil in the body. 2. Check for pressure, resistance after you have tightened the caps with oil in the shock bodies.<o></o>
Tires:[/b] If you haver never glued tires,find a video on youtube or something. The Axial instructions are worthless[/b].<o></o>
<o> </o>
<o>That's a triple worthless for the instructions, but I still got it together, and had a blast doing it. I'm not much helpfor shocks and tires, so if anybody wants to chime in, that'd be appreciated. note: I'm in China, no youtube.com </o>
