RE: Testing the new NV (Norvel) .40 size (6.5cc) gasoline glow engine
Hey Downunder,
Northern Velocity, huh!
Thanx for the info, the prop shaft stud and captive prop washer along with the AME casing all seem rite-on! I was going to carry the shaft stud with me when trying to match up the hub nut, but some sizes, both SAE\metric will "fit".
If I read rite, the prop hole needs to be 1\4" to ride on the machined center of the stud?
Bill, Interesting to see reference to the K&S tubing by both you and the NV instructions, as I had previously purchased both small & medium size to use with Sullivans' universal tank bung. I have seen some posts where others have disregarded the quality of it. Some engine size ranges, I do have nitro, diesel & gas. I also like the Edson mounts where I'll be mounting different engines.
Another question, have you used castor other than Klotz ? and once mixed did it work as well as ? My LHS doesn't have the Benol, but I do have some Sig on hand.
Again, Many Thanx
T-man49 in Al
