<span style="font-size: medium">BMI-Models SPITZ Data Log ESC's </span>-A new range of data logging ESC's:
I recently noticed this new range of data logging ESC's:
http://www.bmi-models.com/#en/SPITZ_Controllor/4/1423
" ... With these new Spitz Data-Log Brushless speed controller, that use the latest software, you cannot only control Spitz brushless motors, but every type of brushless motor.
* The ESC records flight data, which can be consulted after the flight with the Program Box.
* The controller can be programmed with the transmitter stick, with the program card or with the program box.
* Large cooling surfaces assure an optimal performance
* The Spitz data-Log controllers are equipped with an S-BEC that offers more current (A), which allows you to use more analog/digital servos (not for OPTO type) ..."</p>
They are available in: 11, 16, 26, 46, 56, 76A ratings all of them have S-BEC, even the 11A one
and also in: 106A, 132A rating -with no BEC (OPTO) -these are not HV, and are rated 2 to 6 LiPo
(see pics). There are no HV (High Voltage) versions of these BMI Data Log ESC's
These ESC's use the jumper program card shown in pic below(-we can only see back of program card-can see this clearly inpic 5).
And they also use the programming box shown in pic below, for reading out data collected.</p>
So: If you want an ESC that logs data (e.g. ESC temperature, voltage, current, motor RPM, etc ) during a flight
-these ESC's could be useful ...</p>
-They seem to be available mainly in a "Combo Pack" along with a BMI motor
e.g.
http://www.rc-point.nl/N_frame.html?..._art_16037.php
BMI Brushless SPITZ COMBO40 motor+ 56A Data Log ESC-139 Euro also see:
http://www.bmi-models.com/Catalogue_...12/N12_P58.pdf
(I cannot see the Data Log ESC'ssold by themselves, at any place so far ...)
pics show: 1, BMI46A Data Log ESC; 2, BMI 136A Data Log ESC; 3, BMIData Log ESC and program card; 4, BMI Data Log program box 5, BMI "Combo" package-motor / Data Log ESC combined -CAN SEE BMI SPITZ PROGRAM CARD CLEARLY; NOTE IT HAS <span style="font-size: small">
<u>6 PINS</u></span> AT TOP OF CARD.</p>
