If you look at his video it works quite well on balsa and that is what I would use it on. I'm also thinking with the brass liners and the right bit it could be used on AC ply or lite-ply. The angle gauge would allow you to drill at weird angles and make some darn nice pushrod exits. Try using your imagination a little, you'll see what I'm thinking. Every good builder has an over developed imagination.
