RCU Forums - View Single Post - Which chinese factories make various brushless motor brands?
Old 03-26-2013 | 03:15 PM
  #78
DrMotor
Default RE: Which chinese factories make various brushless motor brands?
ORIGINAL: Bustabloodklaart Great thread DoctorM
Thanks. ( "Bustabloodklaart" = Bust a blood clot ?)</p>
I confess I can't tell any difference between the Hacker A30 14l and 2814t 820 Torque when fitted in my Sebart Katana.
My Thrust 30 does look different internally to the other 2 though.
a. Hacker A30-14 L V2 (quoted Kv 800) is <span style="font-size: small">EXACTLY THE SAME </span>142g motor as the Torque 2814T/820 (quoted Kv 820 -a difference of 20 in the Kv is neither here nor there ... ). The <span style="font-size: small">ONLY</span> difference between these motors is purely a cosmetic one -differently machined end housings, and a different colour on the outside. I think we are all 100% certain about this ...
-If you take your Hacker A30-14 L apart (very easy to do ...) -you will find that inside, it is IDENTICAL to the Torque 2814T/820.
b. The PA Thrust 30 motor is smaller (105g) than these two, and is basically the same motor as the Torque 2818T/900 and also APACHE APM30-18T (900 Kv). It is more "Hacker A30-M" in size, rather than "A30-L" size</p>
c. <span style="font-size: small">The E-Flite Power 110 </span>-is 490g, with a Kv 295. It is 6354 in size. It has a 5325 stator.
-This is a very similar size motor to Turnigy SK3 6354-260kv -which is 485g and has a 5025 stator with 18T.
Also, could look at the HYPERION Z5025 20T 235 KV (e.g. Robotbirds) -however, Hyperion quotes a weight of 570g for this motor and has lower Kvthan E-Flite 110(-its real weight may well be less than 570g -since most other 5025 motors produced by Sunray Tech weigh ~520g ...).
-There is also the: Foxy C5025/24 195 Kv (Puffin Models, Bristol) and the LiPolice LP-5025 /22T-230KV <span style="font-size: small">(Schweighofer, Austria -they have free shipping to the whole of EU ..)
</span> -both these motors weigh 520g and also have lower Kv's than the E-Flite 160.
-If you want to pay big bucks, then I suppose you could look at a Hacker A60-7 XS V2 28-Pole -which has weight of 480g, and Kv 320.
See: http://www.rcuniverse.com/forum/fb.asp?m=11433501
-Of course, the Hacker, Hyperion, LiPolice and Foxy motors etc etc are all made together by the Sunray Tech factory ...</p>
d. <span style="font-size: small">The E-Flite Power 160 </span>-is 650g with a Kv of 245. It is 6364 in size, and has a 5335 stator.
-This is a similar size motor to a Turnigy SK3 6364-245kv -which is 697g.It has a 5035 stator and is 14T. There are also other SK3 6364 motors which have lower Kv.
-There seems nothing else in the Hacker / Hyperion / LiPolice /Foxy etc range which is of similar weight and size.
</p>
DrMotor is offline
