ORIGINAL: AMB
Makes sense would not get by the piston as quickly,being thicker, better seal between piston and liner thus hold compression martin
Hi Martin,
I think that the higher the oil content the less the compressibilty of the fuel air mix, and its this effect that raises the final amount of pressure in the cylinder.
The seal, well a high oil could help in a worn engine.
Cheers.
