RE: Seagull Gee Bee Z
Thanks Bob! Now I am working on modifying the fuse interior for both fuel tanks. Enlarged the opening to fit the 24oz main tank with space for some foam around it. Cut an additional hole to route the smoke oil tank lines to the engine. Will also have to add a little foam around it, and figure out how to secure it above the servo tray, since there is not enough room below or beside the main tank, and I want to keep it near the CG and centered. Once that is engineered, I am going to fuel proof the entire interior as far as I can reach I just as a precaution should a connection in all that plumbing develope a leak! I used a right angle attachment for the dremel to cut hole for smoke tank lines, worked well;-)
