<span style="font-size: medium">TURNIGY DLUX data logging ESC's vs BMI SPITZ DATA LOG ESC's
</span> -Now: There is another range of data logging ESC's available -the Turnigy dlux range, from HobbyKing.
<span style="font-size: small">Let's compare these two ranges ...</span></p>
Dlux ESC's are available in ratings: 20A, 30, 40, 55, 70 and 100A -all have S-BEC and all have data logging.
(-They are also available in HV versions -in 80, 120, 160A rating -but these have no S-BEC and no data logging. We will not consider these ..)</p>
So: Compared to Turnigy dlux ESC's:
The Spitz 26A is between dlux 20 and 30A
The Spitz 56A is similar to dlux 55A
The Spitz 76A issimilar rating as dlux 70A.
The Spitz 106A does not have BEC, whereas the dlux 100A <u>
does</u> have S-BEC. So there is a difference there ...
Are there any similarities ? LETS LOOK AT <u>PROGRAMMING</u> OF THESE ESC's:</span></p>
BMI SPITZ DATA LOG ESC PROGRAMMING
From Manual:
http://www.bmi-models.com/download/E...al%20DE-EN.pdf
(the BMIData Log Manual is in German, but it is very easy to translate with GoogleTranslate, etc)
CAN PROGRAM:
1 Brake on or off
2 Battery type
3 Rotation reverse
4 Soft start (Acceleration)
5 Low Voltage Cut-off (LVC)
6 Timing
7 Switching Frequency
8 Restore Factory Default Setting
9 Active RPM Control (Heli Governor mode)</p>
TURNIGY DLUX ESC PROGRAMMING
From Manual:
http://www.hobbyking.com/hobbyking/s...84X7478X51.pdf
CAN PROGRAM:
1 Brake on or off
2 Battery type
3 Rotation reverse
6 Timing
<span style="font-size: medium">FOR PROGRAMMING, THEY ARE <u>IDENTICAL</u> ...!
-NOW WE ARE STARTING TO GET THE PICTURE ...</span></p>
