<u><span style="font-size: medium">LIST OF:</span></u><span style="font-size: medium"> INEXPENSIVE MOTOR,FOR 50-SIZE PLANE: Suitable for 16x8 prop, and 5S LiPo
</span>Here are some motor choices that will perform very similarly to the Hacker A50-14 S. They all have a Kv close (-ish) to 420, and weight around 345g.
Let us keep in mind that <span style="font-size: small">
the Hacker A50-14 S costs £114.69 (in the UK).</span>The Hacker has a 4025 stator, and is ~5055 in external size (i.e. 50mm diam and ~55mm long).
The motors below are listed in order of price: Prices arein£ (english pounds, the Queens own currency)
-Here are the first 8 -there are probably more motors out there than the ones I have found, but I have found enough of them:</p>
1. XYH C 5505 / 08, Kv 400, 310g, D50 L55-
http://en.xingyaohua.com/html/play/411.html
-Can use prop up to 17x9; max power 1450W, This is the XYH "C-type" motor.
£21.33 -
http://www.giantshark.co.uk/xyh5055-...-p-403284.html</p>
2. XYH N 5505 / 07, Kv 400, 329g, D50 L55-
http://en.xingyaohua.com/html/play/429.html
-Can use prop up to 17x9; max power 1560W. This is the XYH "N-Type" motor -higher quality, slightly heavier motor than C-type.
£28.22 -
http://www.giantshark.co.uk/n505507k...-p-407750.html</p>
3. XYH 5065 / 06 410kv ,381g, KV 410, D50 L65-
-Has right Kv, slightly heavier than 345g, and is 65mm long. This is the XYH "C-type" 5065 motor
£31.11 -
http://www.giantshark.co.uk/xyh5065-...-p-404748.html</p>
4. Turnigy G46 Brushless Outrunner 420kv (.46 Glow), 300g, D50 L55
-Probably not powerful enough, is only 300g -similar to E-Flite Power 46 but with a lower Kv (-and is 30% of price of E-Flite ...)
$47.84 = £31.49 -
http://www.hobbyking.com/hobbyking/s..._46_Glow_.html</p>
5. Turnigy SK3 5055-430kv, 370g, 12T D50 L 59
-Really excellent motor, made in Sunray factory along with Hacker, Hyperion etc. Has almost identical internal parts to these. Seems very similar to Hacker A50-14 S (except has 4030 stator, and is slightly heavier). Has very good user comments:
"... run a 17x10 TGS prop at 6690 RPM. The static traction is 5 kg"; "using a 18X8 Xoar prop w/ 6S5000 Turnigy 40c batteries and this is the ticket. Over 5900g thrust at 79A is good for Osires 62 ..."; "... The plane used was a 3D hobby Shop 70" AJ Slick weighing in at 9.25 lbs. Excellent performance (with this motor) as noted above ..."<span style="font-size: small"> -This motor is 28% of the price of Hacker A50-14 S ...!
</span>$49.23 = £32.40 -
http://www.hobbyking.com/hobbyking/s...ner_Motor.html</p>
6. Tacon Big Foot 60, 420g, 400KV, D50 L 65-this motor seemsvery similarto XYHN 5065, andmay well be made by XYH.
-Has right Kv;75g more than Hacker A50; is 65mm long;is 40g more than E-Flite 60 -
SO THIS TACON 60<u>NOT</u> IDENTICAL TO E-FLITE 60
$49.55 = £32.61 -
http://www.hobbypartz.com/96m606-big...030-400kv.html</p>
7. EMax BL4030/06, Kv 420, 320g, D50 L58 -
http://www.yinyanmodel.com/En/ProductView.asp?ID=193
-With 5S LiPo, 17x8 prop, gives 4.9 kg thrust, Has right Kv and weight. Has 4030 stator.
£33.39 -
http://www.giantshark.co.uk/epower-g...-p-405978.html
("E-Power" are Emax motors at Giant Shark)</p>
8. EMax BL4030 385KV, 362g, Kv 385, D50 L58 -
http://www.yinyanmodel.com/En/ProductView.asp?ID=50
-With 5S LiPo, 16x10 prop, gives 4.2 kg thrust; has 4030 stator; -Kv of this motor slightly too low -is more like Hacker A50-16 S
£34.78 -
http://www.giantshark.co.uk/epower-b...tor-p-257.html
£33.45 -
http://www.modelaccessories.co.uk/em...att-410kv.html
</p>
