ORIGINAL: EQ1
ORIGINAL: Maxam
did you adjust a valve way too tight and it is hitting a piston? Unlikely but maybe possible.
No, it was before beginning to adjust the valves and the factory setting showed very much clearance in the range of .025 mm compaired to the .01 which is stated in the manual (checked on several rotations). I am wondering whether they really did a test run at UMS for 20 minutes. Now I don't know, should I start the engine or not? Didn't expect to be faced with such a problem ...
EQ 1 I know this may sound like a pain in the b*** but maybe you should send it back to Horizon and let them test run for you tell them but something doesn't sound right. Or you can try starting it, and if something does not sound right they do stand behind this engine
