RCU Forums - View Single Post - Which chinese factories make various brushless motor brands?
Old 03-29-2013 | 05:46 AM
  #101
DrMotor
Default RE: Which chinese factories make various brushless motor brands?
<span style="font-size: small">HERE ARE THE NEXT 6 MOTORS:
</span>
9. XYH N 5065 / 05, 421g, KV 410, D50 L65 -http://en.xingyaohua.com/html/play/429.html
-Also has right Kv, but is 75g heavier than Hacker A50, and is 65mm long motor. XYH "N-Type" motors are heavier than "C-type"
&pound;35.82 http://www.giantshark.co.uk/n506505k...-p-407744.html</p>
10. Suppo 4130/6 430kv (Power 60 equiv.), 400g, D 50 L65
-Suppo motors have been around for long time; Has ~right Kv, is ~50g heavier than Hacker.
-Also see BP Hobbies for Suppo motors - http://www.bphobbies.com/view.asp?id=V450327
$55.99 = &pound;36.85 - http://www.altitudehobbies.com/brush...C&amp;limit=50</p>
11. GForce G60 (5065), KV400, 360g, D50 L65
-Looks like a well made motor, has right Kv and weight; is a 65mm long motor; May be similar to XYH C-type 5065 motor.
$58 = &pound;38.17 - http://www.valuehobby.com/power-syst...g60-kv400.html</p>
12. Neo 60-410 Motor, 440g, Kv410 D 50 L65mm-looks just like an XYH N 5065 motor (must be made by XYH ...)
-Is almost 100gheavier than Hacker A50 motor;Kv about right; is a65mm long motor
-Esprit website states that is suitable for Hangar 9 Funtana X50 -and can be used on 5S Li-poly with an 18x10 APC-E prop
$69.00 = &pound;45.41 - http://www.espritmodel.com/neo-60410...ess-motor.aspx</p>
13. LiPolice LP-4025 /16T-385KV, 335g, D50 L52
-Made in Sunray factory along with Hacker, Hyperion etc; it is<span style="font-size: small">identical internally to the Hacker A50-16 S motor</span>; However, Kv is too low for this application, just like it is for theHacker A50-16 S motor.
52.90 Euros = &pound;44.63 - http://www.der-schweighofer.at/en/pr...4025_16t-385kv
-NOTE: <u>SCHWEIGHOFER HAS FREE SHIPPING TO ALL COUNTRIES IN EU</u> (for all orders &gt; 90 Euro)
<span style="font-size: small">BASICALLY WE HAVE HERE: </span><span style="font-size: small">A &pound;115 HACKER A50-16 S MOTOR, FOR JUST &pound;44.63 ... That is a good deal</span></p>
14. BMI SPITZ 60, 325g, Kv 460 - http://www.bmi-models.com/#en/85556_...0_40S18/6/1421
BMI SPITZ motors are also made in the Sunray factory, are identical to Hacker, Hyperion, etc; This motor is same as either Hacker A50-14 XS (but has lower Kv of 460) or else is same as Hacker A50-14 S V2 ( -It is probably an identical motor to: Turnigy SK3 5045-450kv )
89 Euros = &pound;75.08 - http://www.model-discount.eu/modelis...-60-278-0.html
</p>
DrMotor is offline
