ORIGINAL: az3d
If it has a wing tube balance it where the tube is. That should be where your measurement is.
If I remember this correctly the g shark has a one peice wing. The middle of the wing would in fact be the root. Being able to calculate out the MAC and set to a safe CG based on those calculations is something all R/C pilots should be able to do. Then again most guys set the CG once and never adjust it to optimum. Poor CG, it's so misunderstood.
