RCU Forums - View Single Post - brushless pvc sub
Old 03-31-2013 | 01:04 AM
X1AaronW
Default brushless pvc sub
I am making a brushless submarine that will be powered by an 11.1v lipo. The submarine will be kept as small as possible to keep the power to weight ratio up. What I need to know is how I can do a nose cone. I have no fiberglassing experience and I dont have a wood lathe availiable. I think fiber glass would be easy. Its basically just industrial grade paper machet. Anyway. Im stressing over the nose cone because I want to keep drag to a minimum and the dome cap for pvc pipe isnt long enough to reduce drag very effectively. That and the brushless motor I am using is an outrunner that will be exposed to the water. Bad idea?
