RCU Forums - View Single Post - Moving up to an SR
Old 03-31-2013 | 01:28 AM
Rob2160's Avatar
Rob2160
Default RE: Moving up to an SR
Lots of good advice that I tend to agree with..
Don;'t waste your money on an SR.. i have one and mine has been reasonably OK..
Problems with the SR..
My servos were irregular at best. i replaced them all with Hitechs ($100 extra)
Despite many reports, my tail motor has never failed.. It has been going strong for over 500 flights.. I had the main motor fail and replaced it after about 400 flights
The stock colour, blue and white is terrible for visibility, so I changed my canopy and tail fins to orange (another $70)
Plus, the gyro simply isn't that great and the SR suffers a lot of tail wagging. Here is a vid of mine with the new motor
[youtube]http://www.youtube.com/watch?v=5U-1Phszaqc[/youtube]
I completely understand your logic for thinking of an SR because I was the same and I got my money's worth.. But it is terrible for aerobatics and very sloppy to fly compared to a good 450 TREX or even the Hobbyking Clones.
Don't let anyone tell you the HK helicopters are junk.. I tried the Blade 400 and it failed me 3 times in the first 20 flights (servos - tail belt failure etc) I have since moved to the HK clones and some of them have over 1000 flights without a single issue.. These helis are much more precise than the SR, much more reliable (in my experience) and much more capable..
The kits are so cheap.. IE under $60, so buy two and you already have a full set of spares in the event of a crash..
A single crash in an SR will cost you around $60 anyway.. perhaps more..
Some vids of my super cheap HK Helicopters.. don't be daunted by the build process. its not so bad and you actually will learn a lot..
I was very intimidated by building my own heli but after the first one I loved the build process just as much as flying so i ended up with 12 450 helis...
All still flying perfectly..
Bypass the SR and get yourself an MCPX or a Nano CPX.. when you can fly one of those try a decent 450..
Both of the helis below cost less than half the cost of a Blade SR and are far more powerful, stable, manouverable and capable
[youtube]http://www.youtube.com/watch?v=SRaI0t4n5Do[/youtube]
[youtube]http://www.youtube.com/watch?v=bfXW9vw8Qq8[/youtube]
[youtube]http://www.youtube.com/watch?v=tVH_T1cvm5s[/youtube]
