RCU Forums - View Single Post - Performance Test: Turnigy SK3 2118-2250Kv, 17g, motor
Old 03-31-2013 | 05:54 AM
DrMotor
Default RE: Performance Test: Turnigy SK3 2118-2250Kv, 17g, motor
<span style="font-size: medium">Other similar (actually probably identical) 16g motors, with Kv ~2250, 11T motors: </span><div style="margin-bottom: 0cm">LiPolice LP-1705/11T-2275KV
HYPERION Z1705-11T 2250 KV</div><div style="margin-bottom: 0cm">OK Hobby Infinite A1705-2250, 11T</div><div style="margin-bottom: 0cm">Also:
Hacker A10-15 S, Kv 2320, 15T</div><div style="margin-bottom: 0cm">Shulman FURY SA-10-15S / 2320Kv, 15T</div><div style="margin-bottom: 0cm"> -These Hacker and Fury motors also appear to be identical to the Turnigy SK3 2118 2250kv I tested. The Fury and Hacker have an identical name, and also an identical Kv.</div><div style="margin-bottom: 0cm">
<span style="font-size: medium">Other similar 16g motors, with lower Kv:</span></div><div style="margin-bottom: 0cm">LiPolice LP-1705/14T-1825KV</div><div style="margin-bottom: 0cm">HYPERION Z1705-14T 1800 KV</div><div style="margin-bottom: 0cm">Foxy C1705/14 1825 Kv</div><div style="margin-bottom: 0cm">OK Hobby Infinite A1705-1800, 14T
</div><div style="margin-bottom: 0cm"><span style="font-size: medium">And with higher Kv
</span>Turnigy SK3 2118-2750kv, 9T</div><div style="margin-bottom: 0cm">Hacker A10-12 S, 2900Kv</div><div style="margin-bottom: 0cm">Shulman Fury-SA-10 12S / 2900Kv
(All Hacker, Hyperion-Z, LiPolice, Shulman Fury, Foxy, and Turnigy SK3 motors are made together in the Sunray Tech factory
-this explains their very similar specs)</div>
