RE: OK gujys, I need help on CG
It's really not that complicated. You're probably OK as a starting point with 5 1/4 back from the leading edge where the wing joins the fuselage. If you want to double check, which isn't a bad idea, use an online CG checker. Then adjust as needed, in small increments, after flying.
